This needs more launch control action!
Also I take it that the launch is speed depending (using gt101 hall sensor on drive shaft or front hub) or (clutch switch?) and results in lowering the rev limit and retarding ignition timing also, or just cutting ignition as per normal rev limit?
is the table setup to alter the rev ramp rate after releasing the clutch and getting in motion to reduce wheel spin off the line?
